Network Management
last person joined: 11 hours ago
8.0 Airwave Hardware Requeriments for a 500 device network?
  • 1.  8.0 Airwave Hardware Requeriments for a 500 device network?
    Posted Jul 30, 2014 01:41 PM
    Hi guys,
    I'm checking the Server Sizing Guides for the 7.7 and 8.0 Airwave versions.
    In the 7.7 Sizing Guide shows requirements for a 500 devices network, but in the 8.0 Sizing Guide shows only requirements for a 1500 and 4000 device networks.
    I need to install Airwave 8.0 for a small network with less than 500 devices. So I need to know the hardware requirements for a server with 500 devices maximum.
    Can anyone give me some advice with this?
    Can I use the recommendations given in the 7.7 Sizing guide for a 500 devices networks?
    Also, another question I have is,
    Is it possible to install Airwave using another RAID different than 1+0? The end-customer only has RAID3 in their servers.
    Thanks in advance.
    Regards!
  • 2.  RE: 8.0 Airwave Hardware Requeriments for a 500 device network?
    Posted Jul 30, 2014 04:04 PM
    I think you will be fine following the 7.7 sizing guide.  If anything, maybe give it a little more ram.
  • 3.  RE: 8.0 Airwave Hardware Requeriments for a 500 device network?
    Posted Jul 30, 2014 05:20 PM
    Thanks Michael,
    So I guess following the 7.7 guide will be ok.
    Do you know something about the RAID issue? Is it possible to install Airwave with a server using RAID3 or something different than RAID1+0?
  • 4.  RE: 8.0 Airwave Hardware Requeriments for a 500 device network?
    Posted Jul 31, 2014 05:12 AM
    I think it would be safe to follow the recommended specs.
    Sorry, I know nothing about RAID stuff.
