all I have a client that has an instant cluster being managed by AIRWAVE, but it works with blacklis to free the internet access. the problem is that before AIRWAVE they can delete and add devices in the list of blaclist and internal server, after the management has been to AIRWAVE can no longer delete the blacklist, the internal server until more can be done then the configuration is applied Mac-Address returns to list. can you help me? thank you
what you use to configurate IAP? template or IGC mode?
IGC mode, select the VC, navigate to the page Security > Blacklist, add or delete blacklist mac address.
If the operations can solve the problem?
