Running into a situation where a particular AP305 is going offline. Upon reboot it will run for a few hours then go offline again. Does anyone have any tips on Tshooting an intermittent offline situation? It is connected via pretty long ethernet run into a POE then on to the AP. I could be exceeding the distance a bit but I'm new to the AP Tshooting specifically the Aruba Controller/AP Tshooting
What is powering the access point? Your cabling should not be any longer than 100meters or 300 feet, because the voltage drop will not be able to power the access point reliably. How long is it and can you get the cable tested?
