Network Management
Re: AirWave 8.2.5 VisualRF Issues
How?
same problem here with 8.2.6 version.
@BirdNetworkAdminwrote:
How?
https://your.ip.goes.here/site_list
this will load vrf in flash mode - presuming your browser supports it
Hi....as per my knowledge the SNMP setting for polling periods are default so it is 5 minutes interval.  You can test in the lab: add an AP to a group, wait for it to come up, unplug it, check back eight hours later it is still showing green in VRF.
Occasional Contributor I
another Problem of VisualRF in Airwave Version 8.2.5.1:
I can not switch from Foot to Meter. When I click the Meter Radio Button, it will switch back to the Foot Radio Button.
mfg
Carstro
Try use different browser and check once, I tried in firefox it didnt allowed but in googl chrome it worked fine.
Pavan
If my post address your queries, give kudos and accept as solution!
oh man, I never try an other Browser. ;-)
Ich will check this next time. Thanks.
mfg
Carstro
