Network Management
AirWave won't start after reboot
  • 1.  AirWave won't start after reboot
    Posted Aug 21, 2012 07:17 AM
    Hi Everyone!
    after a reboot of the server the daemons won't start :-( The only daemons which are running are:
    Tue Aug 21 13:13:02 CEST 2012
    PID PPID PGID %CPU %MEM RSS ELAPSED CMD
    1490 1 1490 0.0 0.5 10552 11:55 Daemon::LowLevelServiceWatcher
    1227 1 1227 0.0 0.0 1076 12:20 rrdcached
    How do I start all the other deamons? Which daemons should run?
    Any help would be greatly appreciated!
  • 2.  RE: AirWave won't start after reboot
    Posted Aug 21, 2012 07:47 AM
    I guess the big question is what was done right before that reboot....
    try "amp_disable" then after a few minutes "amp_enable"
  • 3.  RE: AirWave won't start after reboot
    Posted Aug 21, 2012 09:16 AM
    :smileyhappy: what I have done?
    Well - not much really - I wasn't able to log in to the system via web... so I thought maybe I lost my memory due to the heat - tried to do a web-password recovery. Didn't work. Next thought was: why not reboot? :smileyembarrassed:
    So here am I...
    amp_disable // amp_enable didn't do anything good... (waited 5min between disable/enable)
  • 4.  RE: AirWave won't start after reboot
    Posted Aug 21, 2012 09:17 AM
    thank you for your replay BTW!
  • 5.  RE: AirWave won't start after reboot
    Posted Aug 21, 2012 11:07 AM
    found a hint:
    ]# tail amp_events -n 1000
    outputs 1000x
    Tue Aug 21 16:50:54 2012        Restarting service Database     System  System
    how do I have to solve this?
  • 6.  RE: AirWave won't start after reboot
    Posted Aug 21, 2012 12:25 PM
    It seems like the database isn't starting.  Could the server's disk be full? This command would answer that question:
    # df -h
  • 7.  RE: AirWave won't start after reboot
    Posted Aug 22, 2012 03:50 AM
    100% Full.... I guess that is the Problem... THANK YOU FOR YOUR HELP!!!
  • 8.  RE: AirWave won't start after reboot
    Posted Apr 08, 2017 02:53 AM
    Hello.
    I have exactly the same problem, Airwave doesn't start and df -h shows a disk 100% full. But, I don't know what to do next. What can I delete in the disk in order to start the server???
    Thank you.
  • 9.  RE: AirWave won't start after reboot
    Posted Apr 08, 2017 06:29 AM
    Hi ,
    Here are some good ways to free up some space on your server's hard drive when you need to:
    Delete AMP upgrade packages:
    # rm -rf /root/AMP-*.tar.gz
    # rm -rf /root/AMP-*amp_upgrade
    Delete the code from your previous AMP version:
    # rm -rf /root/svn_old
    Delete archived logs:
    # rm -rf /var/log/*.1
    # rm -rf /var/log/*.2
    # rm -rf /var/log/*.3
    # rm -rf /var/log/*.4
    Delete old AMP backups:
    [NOTE: if you choose to do this it is best to save the backup files off to another machine before deleting them.]
    # rm -rf /var/airwave-backup/*003*
    # rm -rf /var/airwave-backup/*004*
    Pavan
    If my post address your query, give kudos:)
