Network Management
QS
[Airwave 7.7.8 and Controler OS 6.1.3.1 (Model 650) ]
[HOME/FIREWALL] tab shows me nothing at all despite Airwave has been declared in the Controler's config ?
Do I have the righ OS on the controller tought ?
Best regards.
JM
Aruba
Re: [Airwave 7.7.8 and Controler OS 6.1.3.1 (Model 650) ]
Despite your version of AirWave, AppRF Visibility was introduced in ArubaOS 6.3.   Unfortunately, even in 6.3, the 620/650 controller hardware does not support AppRF Visibility, you'll need a 3000 or 7200 series controller.
AMFX | ACCX | ACDX | ACMX
QS
hello,
RF (both capacity and perfs seem OK) , though FIREWALL tab shows nothing.
Regards and thanks for answering
Tim Cappalli | Aruba Security
QS
Thanks sir !
