Network Management
Airwave 8.0.2 - Changing to Instant-GUI and settings not there
I'm in the process of deploying an IAP225 cluster to be managed by Airwave 8.0.2.
There was some delay in setting up the Airwave server, so I went ahead and did all the config on the IAPs.  Now I have Airwave up and running, I'd like to do the config via Airwave with the Instant-GUI.
I enabled Instant-GUI, which was fine, but none of the settings are showing there.  Have tried various things such as auditing and it still shows a blank config.
I'd rather not have to redo all the config again, and pretty sure it is just something I've missed.
Any advice please?
ACCP, ACCX #817, ACMP, ACMX #294
Aruba
Re: Airwave 8.0.2 - Changing to Instant-GUI and settings not there
I assume the desired IAP (the one with the config you want) in your new IAP group?   Did you add/move it manually or did you specifiy the group at the time the IAP was added to AirWave?
If you moved it into this group and  you have the original group still on AMP, you can see if you can copy the settings from it (below).  If you specifified the group during your join to AirWave, it should have created it with the settings.
Within your Instant GUI Config settings:
AirWave --> AirWave Settings --> Copy policy from group:
AMFX | ACCX | ACDX | ACMX
The group was created when I joined it to Airwave, but the settings haven't been populated.
Interestingly, I can see the config if I go to Airwave --> Config history, but the ssids don't show when I click on Network.
Aruba
Try to disable Instant GUI Config on your group; save; and then reenable it.
I just did a quick test with a new cluster.  Adding it to AirWave when the group did not exist worked fine.  When adding, the group was created with the name in the Organization field of the AirWave settings.   I then added the "new device" (the VC) in monitor + firmware updates and it added it to the group.  Enabled the Instant GUI Config and after a sync, settings appeared.  No further interaction.
Doing the same with a preexisting Group did not yield the same results.   When enabling IGC, the group does not display my VC in the Instant GUI Config tab; but I do see my settings in the template.   Disabling and reenabling IGC made it appear.
I tried again, but just keep getting the same thing.
I saw this error as well.
Aruba
Currently, support for 6.4.0.0-4.1.0.0 is only available through template configuration; not IGC (Instant GUI Config).   I believe support is slated for 8.0.3.   UPDATE (see below); 8.0.4 is now the target.
That'll explain it.  Thanks
I believe igc is supported on IAP 4.0 but not 4.1. thanks for this thread will help in the future.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Valued Contributor I
AW 8.0.3 is now the target for support of IAP v.4.1 IGC and should be out by the end of this month.
** UPDATE **
The version for IGC has changed, however, the ETA of IGC for 4.1 stays the same.  Engineering needed to fix a critical issue and that fix is coming in 8.0.3 very shortly.  8.0.4 will now be the version for IGC of IAP v.4.1 and is still targeted for end of the month.
Aruba
AMP 8.0.4 is now available and includes support for IGC on 4.1(.1).
From the Release Notes:
AirWave Support for IAP
AirWave 8.0.4 now supports the following IAP features:
  • IAP4.1.1CLIintemplatemode.
  • InstantGUIConfig(IGC)supportsIAP4.1.1.
