Network Management
Frequent Contributor II
Airwave 8.2.5 Topology map
Is there any way to edit the topology map in Airwave? Would like to group the nodes differently to more closely align with physical layout by building.
Moderator
Re: Airwave 8.2.5 Topology map
Have you tried pinning the devices in place and then manually moving things to the view you like (this pinned view only lasts for the duration of the session - I assume you're looking for something more permanent which would lean toward a feature request)?  There's no automated way to do what you're suggesting.  The logic for the display comes from the data returned by the switches and controllers.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Wasn't aware of the pinning option - that's somewhat helpful but, as you suggested, a feature request is probably the thing to do......
is this is the stie to request this feature?
https://innovate.arubanetworks.com
i have a few clients with this feature and the first thing they tell me is a complain about this.  Like this is really cool but we need that.
Cheers
Carlos
Alternetworks Corp
Moderator
yes, that's the site to submit feature requests.
Rob Gin
