Network Management
Airwave APPRF - Web Reputations & Categories
Hello All,
I want to first apologize if this question has been answered. I looked around, but couldn't find anything that matched my specific problem. I recently enabled AppRF DPI and Web Categorization on my 7210s. It appears to be working on the controllers, but I am not getting the Web Reputation or Web Categories on Airwave. AMON appears to be working correctly, but I am not seeing any other signs of issues. Here is some info to go along with this.
AOS: Version 6.4.2.12
(SPS-7210-0) #show mgmt-servers
List of Management Servers
Type     Primary Server  Profile
AirWave  192.168.11.35   default-amp
Num Rows:1
(SPS-7210-0) #show mgmt-server profile default-amp
Mgmt Config profile "default-amp" (Predefined (editable))
Parameter       Value
Stats           Enabled
Tag             Enabled
Sessions        Enabled
Monitored Info  Disabled
Misc            Enabled
Location        Enabled
UCC Monitoring  Disabled
AirGroup Info   Disabled
Re: Airwave APPRF - Web Reputations & Categories
You should execute:
#show mgmt-server message-counters process fw_visibility
To make sure all data is being sent...
Thank you for your response.
It appears this may be part of my issue.
(SPS-7210-0) #show mgmt-server message-counters process fw_visibility
Message Counter History
Message Number  Time                      Packets  FW Agg Sessions  FW DNS  FW Apps  Web Category Info  Web CC Info
6024            Mon Apr 11 10:24:10 2016  1        269              0       0        0                  0
6023            Mon Apr 11 10:24:10 2016  1        0                0       0        0                  4
6022            Mon Apr 11 10:24:10 2016  1        0                4       0        0                  0
6021            Mon Apr 11 10:22:18 2016  1        327              0       0        0                  0
6020            Mon Apr 11 10:22:18 2016  1        0                0       0        0                  11
6019            Mon Apr 11 10:22:18 2016  1        0                8       0        0                  0
6018            Mon Apr 11 10:20:10 2016  1        351              0       0        0                  0
6017            Mon Apr 11 10:20:10 2016  1        0                0       0        0                  8
6016            Mon Apr 11 10:20:10 2016  1        0                7       0        0                  0
6015            Mon Apr 11 10:18:18 2016  2        401              0       0        0                  0
6014            Mon Apr 11 10:18:18 2016  1        0                0       0        0                  79
6013            Mon Apr 11 10:18:18 2016  1        0                39      0        0                  0
6012            Mon Apr 11 10:16:10 2016  1        309              0       0        0                  0
6011            Mon Apr 11 10:16:10 2016  1        0                0       0        0                  13
6010            Mon Apr 11 10:16:10 2016  1        0                16      0        0                  0
6009            Mon Apr 11 10:14:18 2016  1        275              0       0        0                  0
6008            Mon Apr 11 10:14:18 2016  1        0                0       0        0                  1
6007            Mon Apr 11 10:14:18 2016  1        0                1       0        0                  0
6006            Mon Apr 11 10:12:10 2016  1        310              0       0        0                  0
6005            Mon Apr 11 10:12:10 2016  1        0                0       0        0                  9
I would open a tac case. The controller looks like it is sending the traffic. Airwave somehow is not displaying it.
I will definately do that. Thank you for your help. I will definately post the resolution here as well.
Just wanted to post a resolution here.
After working with TAC over the past week it appears I may have fixed it. I upgraded to 6.4.3.7 last night to gain the "Clarity" insight and as a result it looks like Web Reputions and Web Categories is now populating. I was previously running 6.4.2.12, so I am not sure if this was the issue or not. Hopefully its something someone can try. Thank you for the help
