Network Management
Airwave - AppRF report, top destinations not filtering on role or ssid
  • 1.  Airwave - AppRF report, top destinations not filtering on role or ssid
    Posted Oct 09, 2015 09:41 AM
    I am trying to run an AppRF report in Airwave for a particular ssid and role.  What I am seeing is that the top applications and top destinations charts seem to include all ssids/roles.  I can tell this because there are some destinations listed which are blocked in the particular role.
    Further down, there is a chart for that role, but it only shows the applications.  There is not one for the destinations.
    Is this expected behaviour?
  • 2.  RE: Airwave - AppRF report, top destinations not filtering on role or ssid
    Posted Oct 23, 2015 11:41 AM
    Do you have a screenshot of the options as well as the output of the report?  You might get better service if you open a TAC case in parallel, so that they can take a look at the specifics.
  • 3.  RE: Airwave - AppRF report, top destinations not filtering on role or ssid
    Posted Oct 27, 2015 02:00 PM
    I think this is just the way it is.  The filter is not applied to the 'top application' and 'top destinations' charts.
    I put in these options.
