Network Management
Airwave Device name
  • 1.  Airwave Device name
    Posted Mar 21, 2017 09:42 AM
    I just noticed under the APs/Devices list that airwave is showing the name of my accesspoints as well as the name of the switch its connected to in parentheses.
    Example AP101-office-VP (AP124-r1-1b116.company.com)
    Im not running AP124s any more and only have 225. Im trying to figure out 1, how did the switch name just start coming up, and 2 why it shows AP124?
  • 2.  RE: Airwave Device name
    MVP EXPERT
    Posted Mar 21, 2017 09:55 AM
    Hi, are you able to post a screenshot to help us understand further? Are you certain the switch hasn't been added to AirWave using SNMP polling or anything? Same with the AP124, if these have apppeared on a controller then they will be displayed in AirWave.
    What does the devices details say when you drill down into the AP124's in AirWave?
  • 3.  RE: Airwave Device name
    Posted Mar 21, 2017 10:02 AM
    I am not able to, PAVAN below suggested a solution, and it worked. Now im just trying to figure out why it happened on some of them, but not all of my APs.
  • 4.  RE: Airwave Device name
    Posted Mar 21, 2017 09:56 AM
    Hi Pigpen,
    In AMP Setup > General page>Display section , set AP Fully Qualified Domain Name Options to Do not use FQDN and check the status.
    Pavan
    if my post address your query, give kudos:)
  • 5.  RE: Airwave Device name
    Posted Mar 21, 2017 10:01 AM
    That did the trick. Im trying to understand why some APs were showing the FQDN and some werent?
  • 6.  RE: Airwave Device name
    Posted Oct 01, 2018 03:05 AM
    I have an issue where in the Device Name is not showing up for the Switch for a partcular Group only.
    In the attached sceenshot, the first highlighted field is empty. But its showing correctly for other groups.
  • 7.  RE: Airwave Device name
    Posted Oct 01, 2018 03:31 AM
    Dear ,
    In our device list is showing properly controller and device model .
    Firmware is using 8.2.7
  • 8.  RE: Airwave Device name
    Posted Oct 01, 2018 05:49 AM
    As mentioned, the issue is only with particular group
  • 9.  RE: Airwave Device name
    Posted Oct 01, 2018 10:14 AM
    I suggest opening a support case. I'd expect that if it works in 1 group, it should work for all groups.  Support can at least run some captures and check the logs to see if anything stands out about the group.
  • 10.  RE: Airwave Device name
    Posted Oct 02, 2018 09:44 AM
    Ankita,
    Does Audit configuraiton option enabled in that particular Group>Basic page, if not try enable and  do manual audit from APs/Devices>Config page and import the setting.
