Network Management
Airwave Discovery/Configure Blank IAP
  • 1.  Airwave Discovery/Configure Blank IAP
    Posted Jul 09, 2018 11:55 AM
    We've been using Airwave to manage all of our clusters the past couple of months. I had a question though. Here's the scenario:
    We want to open a new office with its own IAP cluster, is there a way for Airwave to discovery the blank IAP and then we configure the IAP via Airwave? The way we've been doing it up until this point is configuring the IAP via the "instant" SSID and then shipping out the IAP. I hope I am explaining this query well enough
  • 2.  RE: Airwave Discovery/Configure Blank IAP
    Posted Jul 09, 2018 12:09 PM
    If you use DHCP option, you can assign the IAP to the AirWave server over DHCP, it will join a group and get the config from that group.
    Another alternative is if you use Aruba Activate.  This is a remote host that the IAPs can dial into, it will perform a similar operation like DHCP could.
    These are detailed in the AirWave Instant Deployment Guide
