Network Management
Contributor I
Airwave Instant Configs
We are using Airwave to manage Instant AP's, we have multiple Authentication servers being pushed out to each site and each time we have to create these servers on each instant config in Airwave. Anyone know if it's possibly to set this up as a profile for these servers so we don't have to recreate them everytime although they are the same?
Instant Config > Security > Authentication Servers
Trusted Contributor I
Re: Airwave Instant Configs
the instant section is the better place for this question.
but if you create them on the top level they should be available on all lower levels i believe.
are you use templates or instant gui config?
Valued Contributor II
Yes. My friend.
You can have multiple configurations and keep them in Airwave and you can push as per your requirement.
Please feel free for any further help on this.
Venu Puduchery,
