Are there, or anyone know of, any limitations regarding the number of groups that can be created in Airwave?
I may have a use case for over 200 groups.
No limitation. The more groups you have though, the more db space it will use for the additional group settings. So if disk usage is high, then you might need to increase disk sizing.
