Network Management
Airwave - Radius Issue report
  • 1.  Airwave - Radius Issue report
    Posted Feb 04, 2013 04:38 AM
    Just wondering about this report and the issues reported.  What exactly are the issues that are reported?
    Is it the server timing out or is it just a count of client failures?
  • 2.  RE: Airwave - Radius Issue report
    Posted Feb 04, 2013 11:31 AM
    I like to use the stat to track timeouts form the controller side and compare them to my stats from the Authentication Server.
  • 3.  RE: Airwave - Radius Issue report
    Posted Feb 04, 2013 02:30 PM
    The report is supposed to be a gauge for RADIUS issues.  If you have multiple controllers, it can help pinpoint if any of the controllers are having difficulty authenticating clients - this may require manual trending over several report periods.  If you have multiple RADIUS servers, it can point out if any servers are causing a bottleneck.  You can also define which clients are observing failures, and seek out those users to pro-actively tackle authentication issues.
