Network Management
Airwave Restore Nightly Backup Failed!
  • 1.  Airwave Restore Nightly Backup Failed!
    Posted Aug 12, 2016 02:41 AM
    Hello Everyone ..
    Recently i did backup to my airwave server through webui the file size was 71GB , also i copied the last nightly backup (2gb) throuch winscp from airwave-backup folder ..
    right now i'm trying to restore them to a flat new airwave installation ..
    using "./amp_restore -d /tmp/nightly_data.tar.gz" ,
    unfortunately this script doesnt work well .. any ideas ?
    _______________________________________________________--
    output from the 71gb file :
    [root@localhost scripts]# ./amp_restore -d /tmp/nightly_data.tar.gz
    pigz: skipping: <stdin> is not compressed
    /bin/tar: var/airwave/rrd/system_bandwidth*: Not found in archive
    /bin/tar: Exiting with failure status due to previous errors
    No system bandwidth rrd found, assuming normal amp restore at ./amp_restore line 71.
    [Fri Aug 12 08:54:23 IDT 2016] Verifying completeness of /tmp/nightly_data.tar.gz ...
    [Fri Aug 12 08:54:23 IDT 2016] Error: no database backup found in /tmp/nightly_data.tar.gz!
    output from the 2gb file :
    [root@localhost scripts]# ./amp_restore -d /tmp/nightly_data001.tar.gz
    pigz: skipping: <stdin>: corrupted -- incomplete deflate data
    pigz: abort: internal threads error
    /bin/tar: Unexpected EOF in archive
    /bin/tar: Error is not recoverable: exiting now
    [Fri Aug 12 09:27:54 IDT 2016] Verifying completeness of /tmp/nightly_data001.tar.gz ...
  • 2.  RE: Airwave Restore Nightly Backup Failed!
    Posted Aug 12, 2016 06:56 AM
    Are you restoring it to the same version of Airwave?  71GB is very, very large....
  • 3.  RE: Airwave Restore Nightly Backup Failed!
    Posted Aug 15, 2016 07:17 PM
    As Colin mentioned 71G is too much of a big file we have never seen.
    I would like to take a look at the issue. Can you please open a ticket at support@arubanetworks.com and let me know the case number.
    Regards
    Gowri Amujuri
