Network Management
Airwave and Aruba 2920 Switch
  • 1.  Airwave and Aruba 2920 Switch
    Posted Jun 09, 2017 08:06 AM
    I have added Aruba 2920 switch to Airwave and it works fine. However, I have noticed in the Device List that I have 2 new instances of that same device which I did not create. I deleted those two devices but they appeared again.
    As you can in see in the picture, I have created device STHW-SW7D-16 while these other two devices STHW-SW7D-16-2 and STHW-SW7D-16-3 have appeared and keep appearing even after I delete them.
    Best Regards,
    Naida
  • 2.  RE: Airwave and Aruba 2920 Switch
    Posted Jun 09, 2017 08:09 AM
    Hi Naida,
    We see this entries if swtich is been stacked. Check whether any stacking is done.
    Pavan
  • 3.  RE: Airwave and Aruba 2920 Switch
    Posted Jun 09, 2017 08:16 AM
    Hello Pavan,
    Thanks for the help. There are 3 switches in the stack.
    Best Regards,
    Naida
