Network Management
Airwave and IAPs
Hi All,
Does each install AP communicate rogue detection events back to Airwave or will all events come from the "Virtual controller" AP?
I suspect they come from each AP.
Cheers
James
Cheers
James
Re: Airwave an IAPs
BUMP :)
Cheers
James
Moderator
Re: Airwave an IAPs
Bump acknowledged.  I'll have someone in the QA team look into this and respond.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Re: Airwave and IAPs
each AP report rogue info to VC(master actually), then VC report aggregate informate to Airwave.
Great, thanks for letting me know.
Cheers
James
