Network Management
gem
Contributor I
Airwave client connection modes and reporting issues
[ Edited ]
I have noticed a few issues with Airwave on how client connection modes are being classified.
a) I see no 2.4Ghz clients on airwave
b) The connection modes don't really make sence (what is 802.11ag as opposed to 802.11a and 802.11g?) or there are some missing.
Anyone else noticed this? Is it a bug or has something gone wrong on oure server?
Additionally, we would really want to see the Spatial Streeam information for the clients on the reports.
We now that the controllers send the information (eg: a-VHT-40sgi-2ss, a-HT-40sgi-3ss, g-HT-20sgi-1ss).
 AMP: 8.0.11
Controllers: 7020, 7040, 3600
F/W: 6.4.2.13
Moderator
Re: Airwave client connection modes and reporting issues
Please open a support case.  The reported value of 'ag' comes from the AP's response for radio type.  Please also update with AMP version, controller/AP type and firmware version.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
gem
Contributor I
Responce from ATACH:
This has been reported bug on 6.4.2.12, 6.4.2.13, the problem here is that same data is being interpreted differently on the MIBS and AMON which is causing the problem.
Fix: Verified in 6.4.2.13 build 51981 + 52246 and Verified on 6.4.3.4
gem
Contributor I
The feature request for number of Spatial Streams supported by clients still remains...
