Network Management
Airwave discovery
  • 1.  Airwave discovery
    Posted Jul 14, 2015 12:34 PM
    I setup AMP but the discover does not pick up any devices. If I add my Aruba controller manually it picks it up but cannot read any of the configuration for it or the APs. Using snmp v1 & v2. Any suggestions?
  • 2.  RE: Airwave discovery
    Posted Jul 14, 2015 12:42 PM
    Check to see if anything is under New Devices.
  • 3.  RE: Airwave discovery
    Posted Jul 14, 2015 12:52 PM
    yes I see the devices after adding the controller in manually but no config info. Want to do a discovery to pick up all the cisco switches but not working.
  • 4.  RE: Airwave discovery
    Posted Jul 14, 2015 12:58 PM
    The username and password for the device(s) need to be correct for config info.  Double check the username, password and enable password under Manage.
    For discovery to work, you need to enter the correct username and password and snmp string under the manufacturer.
