Network Management
last person joined: 9 hours ago
Airwave - script to move aps to different folder in bulk
  • 1.  Airwave - script to move aps to different folder in bulk
    Posted Jun 25, 2015 09:52 AM
    I have hundreds of APs in the top folder that I need to move into their respective sub-folder.
    Is there a script available to do this in bulk?
  • 2.  RE: Airwave - script to move aps to different folder in bulk
    Posted Jun 25, 2015 11:20 AM
    How many are you moving at a time into sub-folders?
    if you log into the CLI of Airwave, type "scripts" then ls -al, take a look at the scripts there and see if something exists. If not, then you will probably have to go to your TOP folder -> expanded to see all of your devices, then click on modify devices, select the ones you want then select your folder.
  • 3.  RE: Airwave - script to move aps to different folder in bulk
    Posted Jun 25, 2015 11:54 AM
    Each folder which is a site has 2-4 aps.  I have 700 or so to go.
    I had a look in the scripts and unless I'm mistaken there is nothing specifically for moving an existing ap into a different folder.
  • 4.  RE: Airwave - script to move aps to different folder in bulk
    Posted Jun 25, 2015 12:48 PM
    So you have folders with APs within the TOP folder?
    You need to move the APs from that folder to another folder?
  • 5.  RE: Airwave - script to move aps to different folder in bulk
    Posted Jun 25, 2015 12:59 PM
    yes and yes.
    I'm getting through them but given that the folders have on average only 3 aps, it is a slow and laborious process.
  • 6.  RE: Airwave - script to move aps to different folder in bulk
    Posted Jun 25, 2015 01:01 PM
    ok, Airwave allows you to move folders (with devices in it) to another folder
    So let's say you have
    Top -> Folder_a
    you want to move Folder_a to Top -> Client_A -> Folder_A, you can do this.
    It's not intuitive but if you click on Aps/Devices -> Up
    Expand all, scroll to the bottom, edit Folder_a (using pencil), then move it under the appropriate folder....
  • 7.  RE: Airwave - script to move aps to different folder in bulk
    Posted Jun 26, 2015 02:43 AM
    I don't want to move a folder itself.  Besides I can't see any pencil.
    Was hoping there was a script to move the devices so that the csv would be in the format.
    ap_name,existing_folder,new_folder
    I guess I just have to keep clicking away. :-(
  • 8.  RE: Airwave - script to move aps to different folder in bulk
    Posted Jun 26, 2015 10:19 AM
    ya unfortunately looks like you're stuck.
    If my perl skills were up to par i could have written one
  • 9.  RE: Airwave - script to move aps to different folder in bulk
    Posted Sep 13, 2015 11:28 PM
    Are you still looking for a script? May be I can help you if required.
  • 10.  RE: Airwave - script to move aps to different folder in bulk
    Posted Sep 14, 2015 03:17 AM
    I don't need it now, but I'm sure would be useful for the future.
