Network Management
Airwave storage
I have install Airwave i have understood its most of its things.But i am still confused about its storage i.e if after some specific period of time its storage got full how i delete its old logs etc or make a space for incoming logs.
please help me out that how i manage its space.I explore Airwave console but have not found any option,
Re: Airwave storage
Find out what is taking up the space here:
To have alot of it purged, you can lower your data retention time under AMP Setup.  It will be purged at the next nightly maintenance.
Colin Joseph
Aruba Customer Engineering
