I'm currently running airwave 7.7.6, can I upgrade to 8.0 from 7.7.6 ??,
if yes, are there some consideration I can take care with??
Thank you
You can. It is sort of hidden in the release notes:
"Note that updates are only supported from up to two versions prior. Contact support if you are upgrading from three versions prior or more (for example, from 7.4 to 7.7). "
