Network Management
Airwave vs no Airwave in controller based deployment
  • 1.  Airwave vs no Airwave in controller based deployment
    Posted Nov 04, 2015 04:39 AM
    Hi!!!
    Other than visual rf, location tracking and generation of reports. What are the other benefits of deploying Airwave in a controller wireless deployment.
    Thanks alot!!!
  • 2.  RE: Airwave vs no Airwave in controller based deployment
    Posted Nov 04, 2015 05:06 AM
    I presume that the most imortant are long term trend analysys and extensible troubleshooting. Personally I do not prefer to manage controller-based deployments via AirWave.
    HTH,
    Marek
  • 3.  RE: Airwave vs no Airwave in controller based deployment
    Posted Nov 04, 2015 07:49 AM
  • 4.  RE: Airwave vs no Airwave in controller based deployment
    Posted Nov 04, 2015 07:49 PM
    I like the ability to use one configuration in Airwave to keep 7 master controllers neatly in line, rather than having to make the same changes in each controller and try to keep them in sync.
  • 5.  RE: Airwave vs no Airwave in controller based deployment
    Posted Nov 05, 2015 10:27 AM
    it auto backs up your controllers to which you can restore directly from within Airwave which is a nice feature.
    ability to receive syslog and traps from your controllers so you can be triggered in an any type of event for example if a process dies. http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Tutorial-Using-Airwave-and-SNMP-traps-to-trigger-alarms-based/td-p/140929
