Network Management
last person joined: 9 hours ago
Aruba 2930F - removing trunk - Solved
  • 1.  Aruba 2930F - removing trunk - Solved
    Posted Oct 23, 2017 08:02 AM
    I have a configuration issue with a Aruba 2930F switch with respect to removing a trunk. I successfully configured 2 ports as a trunk:
    trunk 1-2 trk1 lacp
    And in the other end I have a server which also uses LACP. And that works. But now I want to use the ports in non trunk mode, so I remove the trunk using:
    no trunk 1-2
    Viewing the configuration the trunk has been removed, however the server (not using LACP - PXE boot) is unable to establish a connection on either ports (1-2).
    What am I missing?
    Edit: The issue have dissapeared. Maybe it went away after disabling/enabling the interfaces.
    Martin
    #2930F
