Network Management
Moderator
Re: Aruba Airwave AppRF
Thanks all for the updates.  I will have someone in QA take a look at this and update.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Luckyvvt,
We just tried this in our lab but we get full AppRF data in AirWave and the port to application translation works without a problem. Assuming the entier configuration is done correctly on the controller and AirWave, I'd suggest you open a support case so that Engineering can take a look at your setup and debug in detail. Thank you!
Hi, I have the same issue with an Airwave 8.5.2.1 and Controller 6.5.4.3. In all these years, someone found the solution?
Thank you very much!
Hi ,
Airwave recives port to application mapping using AMON feed , if airwave doesn't recive mapping for any port it will show as Port <port no> in AppRF charts
Can you help with this information to check further ?
  1. Are you not seeing any applications in applications graph ? Are all coming as Port ?
  2. Are you seeing the applications in controller ? You can check using below command
show dpi application all
 3 . Do you have root access to your system ? if yes , can you check content in pef_fw_application table , ap_pef_fw_application ?
And it would be better if I can access your systen to check the issue further
Sandeep Lade
Airwave QA team
