Network Management
Can Airwave monitor and alert on the presence/absence of an ACL on a controller port?
  • 1.  Can Airwave monitor and alert on the presence/absence of an ACL on a controller port?
    Posted Mar 25, 2015 03:49 PM
    Just wondering if Airwave can monitor a controller's config and generate an alert if an ACL is not applied to an interface.  I know that config monitoring exists, but there doesn't seem to be a readily apparent way to alert if, for instance, an ACL was removed from an interface.
  • 2.  RE: Can Airwave monitor and alert on the presence/absence of an ACL on a controller port?
    Posted Mar 25, 2015 04:23 PM
    If the ACL is present in the controller config, the config mismatch report should catch it.  But if you want like a trigger/alert, then you're going to want to file it as an RFE.
  • 3.  RE: Can Airwave monitor and alert on the presence/absence of an ACL on a controller port?
    Posted Mar 30, 2015 02:41 PM
    Thanks for your response.  I'll see about the feature request.
