Network Management
Can Aruba Airwave monitor Aruba 2930F POE switch power consumption?
  • 1.  Can Aruba Airwave monitor Aruba 2930F POE switch power consumption?
    Posted Mar 13, 2018 10:34 PM
    Hi all
    thanks
  • 2.  RE: Can Aruba Airwave monitor Aruba 2930F POE switch power consumption?
    Posted Mar 14, 2018 07:25 AM
    Airwave doen not support PoE switch power consumption.
  • 3.  RE: Can Aruba Airwave monitor Aruba 2930F POE switch power consumption?
    Posted Mar 26, 2018 12:38 AM
    Airwave switch integration is very thin, whilst it cannot monitor it, you can set the switch to send traps to Airwave, create an Airwave trigger based on the poe threshold trap (and poe failure) which is sent as a deviceEvent, e.g.
    deviceEvent "Event Contents" matches "Unrecoverable fault on PoE controller"
    deviceEvent "Event Contents" matches "PoE usage has exceeded threshold"
    hth
