Network Management
Channel util graphs distorted
  • 1.  Channel util graphs distorted
    Posted Jun 08, 2018 04:00 AM
    Dear,
    running AMP version: 8.2.6.1
    Controller version 6.5.4.3
    Issue is that some of the channel utilization graphs are distorted, anyone has seen this before?
    We are using SNMP polling.
    Kind regards,
    Thomas
  • 2.  RE: Channel util graphs distorted
    Posted Jun 08, 2018 04:27 AM
    Thomas,
    As far as I know, Channel Utilization is sent to Airwave using Amon, not snmp polling.  Do you have Amon configured on the controller?
    http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Why-you-should-always-enable-AMON-on-your-Aruba-Controller-when/ta-p/72104
  • 3.  RE: Channel util graphs distorted
    Posted Jun 08, 2018 04:29 AM
    I will check with our end-customer, but then you shouldn't see any data when it isn't configured?
  • 4.  RE: Channel util graphs distorted
    Posted Jun 08, 2018 04:37 AM
    Correct.  That means the problem would have to be on the Airwave server either receiving or storing the data through AMON.
    I would try the article here:  http://community.arubanetworks.com/t5/Monitoring-Management-Location/Basic-AMON-troubleshooting-on-Airwave/ta-p/211841 or any other article on AMON troubleshooting to make sure it is being received and that the retention settings are not too high on that Airwave box.
  • 5.  RE: Channel util graphs distorted
    Posted Jun 08, 2018 04:45 AM
    OK Thanks, i will forward it to my end-customer, I don't have remote access for the moment.
  • 6.  RE: Channel util graphs distorted
    Posted Jun 08, 2018 06:18 AM
    I checked with our end-customer and we see the following:
    Looks OK I think?
    We also have run the debug, but we don't know what exactly to look for. Do we open a ticket with TAC?
  • 7.  RE: Channel util graphs distorted
    Posted Jun 08, 2018 06:36 AM
    Yes, open a ticket with TAC. and let us know how it goes.
