Network Management
Configure rogue detection in AirWave 8
  • 1.  Configure rogue detection in AirWave 8
    Posted May 12, 2015 05:23 PM
    Is there a trick to configuring rogue detection in AirWave?
    I see plenty of 'suspected neighbors' but zero rogues
  • 2.  RE: Configure rogue detection in AirWave 8
    Posted May 12, 2015 05:25 PM
    Do you have your edge switching in AirWave?
  • 3.  RE: Configure rogue detection in AirWave 8
    Posted May 12, 2015 05:46 PM
    I do now!
    And the rogues showed up
    Thank you
  • 4.  RE: Configure rogue detection in AirWave 8
    Posted May 12, 2015 05:48 PM
    How exactly does the switch come into play?
    I added a single core switch from one campus,
    and the result is I can now detect rogues at all my sites...
    Which is great, just curious as to why
  • 5.  RE: Configure rogue detection in AirWave 8
    Posted May 12, 2015 05:53 PM
    MAC address correlation. If all of your layer 3s are in that core, then it makes sense.
    Tim
