Network Management
Create and broadcast a new SSID using Airwave
  • 1.  Create and broadcast a new SSID using Airwave
    Posted Jul 31, 2017 08:54 AM
    What is the right way to deploy a new SSID to a group of access points using Airwave? I created one in Airwave under Groups, clicked on group name, clicked on SSIDs in the left hand side menu, added new SSID, and made sure it was enabled for both radios.
    But it still doesnt show on the IAP and can't see it broadcasted.
  • 2.  RE: Create and broadcast a new SSID using Airwave
    Posted Jul 31, 2017 09:08 AM
    We can't push SSID profile to IAPs using Groups>SSID profile, it works only for controllers. If we want to configure IAPs then either we could use templates or enable Aruba Instant GUI config in Groups>Basic page, once enable template option will go away and we see Group>Instant GUI tab.
    Pavan
  • 3.  RE: Create and broadcast a new SSID using Airwave
    Posted Sep 14, 2017 11:13 AM
    We do not control our Controllers with Airwave.  We only use it for locations usign instants.  If I do enable GUI Config will it mess up the settings that we already have?  I don't want to tear up what we have.
