Network Management
last person joined: 5 hours ago
Edit timezone ALE 2.0.0.8 how?
  • 1.  Edit timezone ALE 2.0.0.8 how?
    Posted Oct 20, 2016 03:05 AM
    We are using the ALE 2.0.0.8 server - and his API to receive location presence data to process in our platform.
    We see the timestamp in ALE webgui at 19 october 03:30 PM GMT
    While our timezone is GMT +1 Amsterdam - so our current time is 17:30 (5:30 PM).
    We see in Configuration > Options > NTP server, and typed in a Dutch ntp server.
    But we can not edit Timezone to GMT +1.. so how to be sure ALE server is using correct time?
  • 2.  RE: Edit timezone ALE 2.0.0.8 how?
    Posted Oct 20, 2016 10:35 AM
    Hi Christiaan,
    There are a bunch of files stored by region in the following directory:
    /usr/share/zoneinfo
    Take a look and find the one which matches your region. Then you have to create a symlink from /etc/localtime
    In this case since its Amsterdam, we can follow the below steps,
    # rm -f localtime
    # ln -s /usr/share/zoneinfo/Europe/Amsterdam /etc/localtime
    # /etc/init.d/ale-jwebapp restart
    Vishnu
  • 3.  RE: Edit timezone ALE 2.0.0.8 how?
    Posted Oct 21, 2016 04:04 AM
    Hi there,
    thanks for the response..
    I tried to do the commands, but at second sline, response from CLI > is that file already exists: "/etc/localtime"
    I tried without that part, and then restarted, but no effect. Wegbui still shows UTC
  • 4.  RE: Edit timezone ALE 2.0.0.8 how?
    Posted Oct 21, 2016 07:56 AM
    It is because the localtime file is not removed. Please try the below,
    # cd /etc
    # rm -f localtime
    Now the below commands,
    Vishnu
