Network Management
Guest users in Airwave in state pending.
  • 1.  Guest users in Airwave in state pending.
    Posted Oct 12, 2013 07:26 AM
    I want to use these users for guest access with IAP
  • 2.  RE: Guest users in Airwave in state pending.
    Posted Oct 12, 2013 08:35 AM
    AirWave's guest user accounts are not supported on Instant.
  • 3.  RE: Guest users in Airwave in state pending.
    Posted Oct 12, 2013 11:44 AM
    AirWave 7.7.5 will be out very soon and includes a new UI that mimicks the Instant WebUI.  You can configure users for the Guest DB on Instant there.  Not the same thing you are looking for but it is the next best thing :)
    Here is a preview:
  • 4.  RE: Guest users in Airwave in state pending.
    Posted Feb 21, 2014 01:54 PM
    Is this feature slated for an upcoming release?  With Instant/AirWave deployments, having global guest management as well as self-expiring guest accounts is a must-have.
  • 5.  RE: Guest users in Airwave in state pending.
    Posted Feb 24, 2014 05:21 AM
    if it is indeed part of 7.7.5 then it should be possible now, that version has been out for a while, did you check?
  • 6.  RE: Guest users in Airwave in state pending.
    Posted Feb 24, 2014 11:36 AM
    I have tried 7.7.8/9 and it is possible to create guest users in the vitual controller GUI managment.  The problem is that it is site by site and is very limited for a Guest Administrator to be able to create accounts on the fly.   It would be great, since all the interface is already there, to be able to use the Guest Management in AirWave and have it replicate those guest accounts to all Virtual Controllers managed.
  • 7.  RE: Guest users in Airwave in state pending.
    Posted Aug 14, 2015 10:30 AM
    using 8.0.9 and same problem here , just wondered if it's possible to centralize creatitng guest users on groups or all VC's , but my test user is also having status "pending".
    perhaps cause i dont have controllers added to AMP , only VC/instants...
    so lets do this via IGC per group based, i also would expect that "john doe" only needs to be added on one branch instead of all branches , <- useless if this is a normal guest which is never visiting those branches.
    well another use case would be if having users frequently visiting those branches and so branch1 and branch2 would sync regarding guest users.
    thanks
    ben
  • 8.  RE: Guest users in Airwave in state pending.
    Posted Sep 16, 2015 03:08 PM
    all great ideas, put them in the idea portal and perhaps someday ... :)
  • 9.  RE: Guest users in Airwave in state pending.
    Posted Aug 22, 2014 07:19 AM
    Does anything changed wit this funcionality? I need to time limited ticked for my guest users connecting via IAP.
