Network Management
Occasional Contributor I
HPE 5130 switches unable to add into AirWave NMS server
As per the below post, the HP 5130 with version 7.0 onwards will add into Aruba AirWave NMS but not able to add and showing SNMP get failed error in AirWave.
I am trying to add with SNMPV3, I have tried HPE office connect and Universal device but no luck.
Can anyone provide the solution please....
Switch Model: 5130-24G-4SFP+ EI JG932A
VENDOR_NAME          : HPE
Version 7.0 running
Thanks and regards,
Ashok
Moderator
Re: HPE 5130 switches unable to add into AirWave NMS server
dupe thread - see http://community.arubanetworks.com/t5/Network-Management/HPE-5130-switches-unable-to-add-into-AirWave-NMS-server/m-p/444971/highlight/false#M9291
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
