Is there a way to obtain from AirWave a list of all the urls visited by a user during its session on specific date in the past?
AirWave doesn't get complete URLs from the controller, so you're only going to see the Application or Destination path (usually host domain of the site visited) that the controller sends to AirWave over AppRF which is not maintained for a long time (AppRF consumes a lot of database space). This might be a feature request to make on the controller end to log that level of detail of user traffic. Once the controller passes on that level of granularity - AirWave could follow up with a similar feature enhancement when the data is present.
Thanks for your answer.
So the following question could be:
How can I setup logs in order to store the following information?
[Timestamp, IP addr, MAC addr, url, port]
