Network Management
How to rename a big amount IAPs through airwave?
Hi folks,
as already mentioned in the subject:
How do you rename a big amount IAPs through airwave?
We've a AMP with nearly 800 IAPs and the device name of each access point is its lan mac address.
Is there a way to (at least semi)auto rename all of them ? Maybe through a csv export/import?
We're using AMP version 8.2.2.
Kind regards
Ed
Re: How to rename a big amount IAPs through airwave?
No ideas or suggestions?
I can't be the only one with this problem?
MVP
I just saw this question (I was searching for something else entirely of course)
From the web-interface, there's always the "click edit, select 'rename' and then retype each AP name as you go" method.
Otherwise you might ask TAC to see if they can come up with a database-admin script which could do it.
Renaming in the html-gui is probably safest.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
