Network Management
How to upgrade license in Airwaves
  • 1.  How to upgrade license in Airwaves
    Posted Oct 14, 2013 04:20 PM
    I have an Airwave server 7.7 version with 200 devices licenses and I bought an 50 licenses more but seems like is not working. Just works 200 or 50 but not the 250.
    How can I add/combine it that to get 250 that I bought?
  • 2.  RE: How to upgrade license in Airwaves
    Posted Oct 14, 2013 04:33 PM
    In the licensing.arubanetworks.com website, under Airwave, there is a tab to combine licenses.  If you do not see the tab, send an email to support@arubanetworks.com and they should be able to help you.
  • 3.  RE: How to upgrade license in Airwaves
    Posted Oct 14, 2013 04:54 PM
    This are my options:
    My AirWave certificates --- Activate AirWave certificate --- Consolidate AirWave licenses --- Transfer AirWave license --- Download AirWave Software
  • 4.  RE: How to upgrade license in Airwaves
    Posted Oct 14, 2013 04:55 PM
    Try Consolidate.
  • 5.  RE: How to upgrade license in Airwaves
    Posted Oct 14, 2013 05:09 PM
    Seems like the new license key does not exist.
    "sdfadfsadfasfgdfgadfgadfgdfgsdgfqwertyqweetywqewrty does not exist."
  • 6.  RE: How to upgrade license in Airwaves
    Posted Oct 15, 2013 05:15 PM
    Opening a support case should be able to get that fixed for you quickly.  It would also let them know to get someone to check up on the license consolidation tool.
  • 7.  RE: How to upgrade license in Airwaves
    Posted Oct 16, 2013 03:02 AM
    thanks for your post.
    When i don´t find out my issue on the forum and the combinations and "consolitation" trys doesnt works i open the case ;-)
    I think that the license is not on the "new" licensing webserver database because I bught it few years ago... i have a 5000 controller (2004 controller) with the similar license issue...
    Regards.
  • 8.  RE: How to upgrade license in Airwaves
    Posted Oct 16, 2013 03:09 AM
    Few minutes ago I receive a TAC email with the new consolidated license, I copy and paste and it works.
    Regards.
