Network Management
Management software for Aruba and Aerohive.
Hi. We have a large number of Aruba and Aerohive APs.  Does anyone know of a management software that supports both products?
Frequent Contributor II
Re: Management software for Aruba and Aerohive.
You'll probably find management platforms supporting both but doubt there is anything allowing the two brands to integrate as one WLAN. I might even think AirWave is a possibility as management platform but not 100% sure.
Kind regards,
jcelis
Thanks for the quick reply. I'll investigate AirWave further.
