Network Management
Super Contributor II
Mismatched configuration in AirWave
Hi guys,
I have recently changed the country code in my Instant cluster and had a mismatched event in my AirWave. Then I updated the regulatory domain in Groups > Basic > Regulatory Domain. However, the mismatched event keeps appearing. If I audit the device I get this
I think I have to upload the new configuration into the templates or something like that, but I don't know the exact process to do since I am new in AirWave.
Do you know what I have to do? Could you help me?
Julián
Re: Mismatched configuration in AirWave
To reslove mismatch, navigate to Groups>Template page and fetch the latest template and check the status.
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Hi Pavan,
I fixed the problem, many thanks!
Julián
Hi Pavan,
Im on AMP 8.0.9 and do not have the template option from what I can see. On my end, it shows the configuration does not match the "desired" configuration.. I've tried updating, auditing, imnporting the configuration and it still shows the 2 local controllers and 91 AP's mismatched. It's annoying.
Have you enabled Aruba configuratoin in Groups>Basic page , if yes then it does not show template option.
Does both the controller are placed in same Airwave group? If  configuration is not same on both controllers then we cannt resolve mismatch in Airwave, if you import local 1  controller config it shows stauts as Good but local 2 will be in mismatch, if you import local 2 config local1 go to mismatch.
Try import controller setting from APs/Devices>Audit page and also APs/Devices>Manage page.
Pavan
Pavan
