Network Management
last person joined: 5 hours ago
New to AirWave need some help!!
  • 1.  New to AirWave need some help!!
    Posted Apr 11, 2014 06:27 PM
    Hi Forum,
    I need some help with AirWave server. I installed an OVA on my VM and assigned the AP address and everything. I can SSH to the VM and access the CLI. I can't access the GUI though!! When I Https to the IP address of the server nothin happens and the pages times out. What is it that I need to do(if this is a common issue), may be a command that I have to issue? Please advise.
    Thanks Forum,
    Fahad.
  • 2.  RE: New to AirWave need some help!!
    Posted Apr 11, 2014 06:29 PM
    Try running amp_enable from the CLI.
  • 3.  RE: New to AirWave need some help!!
    Posted Apr 11, 2014 06:33 PM
    Same, nothing :(
    it is V7.7.10 tried from Chrome, Firefox, and IE10
  • 4.  RE: New to AirWave need some help!!
    Posted Apr 11, 2014 07:36 PM
  • 5.  RE: New to AirWave need some help!!
    Posted Apr 11, 2014 07:45 PM
    I did read the installation steps before hand and did exactly what in the document. Do I need a license to enable GUI?
  • 6.  RE: New to AirWave need some help!!
    Posted Apr 11, 2014 07:47 PM
    At the end of the installation, it should have told you the URL to get into the GUI.  Did you follow all the instructions all the way through?
  • 7.  RE: New to AirWave need some help!!
    Posted Apr 11, 2014 07:50 PM
    I did follow everything and at the end of the insallation it said to access the amp through https://192.168.30.197 but it isn't working. I even did ./amp-install and went through the process again and not working.
  • 8.  RE: New to AirWave need some help!!
    Posted Apr 11, 2014 08:09 PM
    I recently did an install and had reboot a couple of times before the GUI started to work
  • 9.  RE: New to AirWave need some help!!
    Posted Apr 11, 2014 08:36 PM
    can you try https://<ip address>/root ?
  • 10.  RE: New to AirWave need some help!!
    Posted Apr 11, 2014 09:21 PM
    At the CLI try:
    /sbin/service httpd restart
  • 11.  RE: New to AirWave need some help!!
    Posted Apr 12, 2014 06:00 PM
    It worked. I contacted my Arubanetworks friends and they told my that I have to wait for some time for the GUI to come up and be usable. I waited 24 hours and tried today and it actually worked. I did no changes at all-it just worked-
    Thanks everyone.
  • 12.  RE: New to AirWave need some help!!
    Posted Apr 11, 2014 07:42 PM
    Try daemons and check if httpd is running if not run restart_daemons.pl
  • 13.  RE: New to AirWave need some help!!
    Posted Apr 11, 2014 08:10 PM
    Connect to the console and see if you can ping your default gateway..?
