Network Management
Quick Questions - Airwave AP Neighbors?
how are they defined as neighbors, i have assumed that it is because they can see them over RF and not on the wired.
I ask because looking at a Single AP - it has 20 AP neighbours which are on my network connected by at least 5 diffrent switches, some in diffrent buildings.
This guessing this is far to many (non high density deployment) and the AP are more powerfull they we anticapted (AP-325).
Re: Quick Questions - Airwave AP Neighbors?
Rapids> Rules determine the classification of access points.  You can change the rules at any time.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
These are classed as AMP AP
I am looking on the AP information and not within the RAPIDS section.
Maybe i have missed it but i can see a rule that classifies AP's as AMP AP
AMP AP means that it is managed by Airwave.
