I haven´t changed anything regarding backup of swtiches and controllers. Have been reading the user guide and it seems it´s configured by default ?
The devices are in monitor mode, but that shouldn´t matter right ?
Controller Backups and Restoration
You can create a backup on demand by creating and collecting a flash backup from the controller. Daily backups are also created. At a minimum, there are four backup files:
| | One backup from last week |
| | One backup from last month |
The backup saved from a firmware upgrade is automatic and requires no manual intervention. All backups can be saved or restored and are displayed on the Audit page. You can only perform a backup on a device if the firmware version of the device and the backup image are identical. After you click Restore, the device on which the restoration is being performed automatically switches from monitor mode to maintenance mode. After you restore a backup image to a device, you must restart the controller."
