Network Management
Contributor II
Solarwinds + IAP and controller
Hi to all,
i would like to know if IAP and controller are compatible to solarwinds NmS?is it thru snmp? my objective is to create centralized reports. any recommendations or docs?
thank you very much
Frequent Contributor II
Re: Solarwinds + IAP and controller
It will depend upon what you are trying to achieve from the reporting.
You can import custom MIBs (Aruba Instant MIBs provided by Aruba) in Solarwinds to monitor the IAP cluster through SNMP.
For a more detailed reporting about the network, I would recommend considering Airwave.
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
