Sometime we need access different vendor.
Hereby some commands to create trunking LACP between Aruba and HPE Comware.
Aruba
1. Create trunk 23 trk1 lacp
Port eth 23 as trunk to lacp.
You can assign trunk number for this point (trk1)
2. vlan 300
name "VLAN300"
untagged Trk1-Trk4
ip address 192.168.0.2 255.255.255.224
exit
Create vlan interface and assign the trunk to vlan.
Assign IP Address to this device.
HP Procurve Comware
1. interface Bridge-Aggregation1
description **To_Switch1
port link-type trunk
port trunk permit vlan all
port trunk pvid vlan 300
link-aggregation mode dynamic
Create interface LACP interface Bridge-Aggregation1 and assign pvid as vlan 300.
Assign link-aggregation mode. You can choose dynamic or static for this point.
2. interface Ethernet1/0/23
port link-mode bridge
port link-aggregation group 1
Assign port int eth 1/0/23 as trunk to Aruba and create lacp port link-aggregation group 1.
Create port trunk pvid vlan 300 for this port to connected between Aruba and HP Procurve Commware.
3. ip route-static 0.0.0.0 0.0.0.0 192.168.0.1
Create routing static on HP Procure Commware to connected this device to link.
