Network Management
last person joined: 3 hours ago
Upgrade path for Airwave 7.6.4 (CentOS 5.5) to Airwave 8.2 (CentOS 6.2)
  • 1.  Upgrade path for Airwave 7.6.4 (CentOS 5.5) to Airwave 8.2 (CentOS 6.2)
    Posted May 19, 2016 11:20 AM
    Please advise on the upgrade path for Airwave 7.6.4 (CentOS 5.5) to Airwave 8.2 (CentOS 6.2)
    Here is what I can gather so far based on a document found here: https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/Migrating-Airwave-from-CentOS-5-5-to-CentOS-6-2
    0. Backup data and copy off Airwave server
    1. Install Airwave using AMP-7.6.4-x86_64.iso (this will update CentOS to version 6.2 only)
    Q: Will doing the above *reinstall* AMP 7.6.4 OVER the current installation, deleting all data?
    2. Restore backup data (depending on answer to above question).
    Q: Do I need to upgrade AMP to an interim version? If yes, what version?
    3. Upgrade AMP to version 8.2
    Thanks in advance,
    Mike
  • 2.  RE: Upgrade path for Airwave 7.6.4 (CentOS 5.5) to Airwave 8.2 (CentOS 6.2)
    Posted May 19, 2016 06:02 PM
    You're on the right track.
    The reinstall step of the newer CentOS version will completely overwrite your system which is why step 0 is very important.  I would strongly suggest that in step 0: grab all backups from /var/airwave-backup as a precaution.
    Once reinstall is complete, restore your backed up date.  Once the backup is restored, make sure to check the UI to make sure the data looks consistent with how it was before.
    The general rule is that you can skip 1 release in the upgrades or you can play it safe and go through each of the upgrades (7.6 -> 7.7 -> 8.0 -> 8.2).  If you want to skip, you should be able to go from 7.6 -> 8.0 -> 8.2.
    At that point, I'd have to run through the upgrade path again to be certain, but I think it'd still show as CentOS 6.2, but a fresh 8.2 install will have CentOS 6.6.  So depending on what the cat /etc/redhat-release value is after the 8.2 upgrade, you may or may not want to repeat step 0, and then reinstall / restore once more so that you're up to date from all angles.
    Another thing since you're upgrading from 2 year old code is to double check that your box is still up to spec.  Several new features have been added that gobble up resources.
  • 3.  RE: Upgrade path for Airwave 7.6.4 (CentOS 5.5) to Airwave 8.2 (CentOS 6.2)
    Posted May 19, 2016 07:06 PM
    Thanks for your help Rob.
    I did an amp_backup which creates a file called databackup.tar.gz in /alternative/. How is that file different than the nightly backups in /var/airwave-backup, and which file do I use to restore?
    To clarify, the "install iso" file does a CentOS + AMP overwrite, whereas the "upgrade package" just upgrades the AMP version and (hopefully) does not overwrite data. Is that correct? If yes, wouldn't I still be on CentOS 6.2 after doing the 7.6 -> 8.0 -> 8.2 upgades?
    Finally, where would I find updated specs for the AMP server?
    Thanks again,
    Mike
  • 4.  RE: Upgrade path for Airwave 7.6.4 (CentOS 5.5) to Airwave 8.2 (CentOS 6.2)
    Posted May 19, 2016 11:37 PM
    Nightly backups are just backups from the last nightly maintenance period (see AMP Setup -> Nightly Maintenance time setting).  The amp_backup script is called as a part of the nightly_maintenance routine.  The difference in running amp_backup is that it will give you a closer backup point (for instance, if nightly maintenance backups are from 10pm, and it's already 10am by the time you're about to perform the process, there's a potential 12 hour extra of data loss - this may or may not be acceptable based on your requirements).  Another difference is that nightly_maintenance runs in the background at a medium priority job while AMP is still available for use, while amp_backup forces the AMP to go offline to perform a relatively quicker backup).
    Correct, the ISO install will reinstall the OS and then you have to do amp-install to unpackage the AMP code after the fresh install.  The upgrade package doesn't include the entire OS which is why it's roughly half the size, but upgrade packages do contain updated RPMs (the version ISO would carry the same updated RPMs).  So if you continue to upgrade with the upgrade package, you will be able to keep up with the latest security patches for the underlying OS.
    Update server sizing guide is located on support.arubanetworks.com under documentation, software, airwave and then navigate to the proper release.  For 8.2.0.2, you'd be looking at this doc link.
  • 5.  RE: Upgrade path for Airwave 7.6.4 (CentOS 5.5) to Airwave 8.2 (CentOS 6.2)
    Posted May 20, 2016 01:47 PM
    Thanks for this excellent overview! I plan to upgrade next week.
    Mike
  • 6.  RE: Upgrade path for Airwave 7.6.4 (CentOS 5.5) to Airwave 8.2 (CentOS 6.2)
    Posted May 23, 2016 01:34 PM
    One more question (isn't there always?)
    The size of my nightly data backup files are much larger than the backup file from the amp_backup output. What's the reason?
    Mike
    backupserver>ls -al
    total 19921272
    drwxr-xr-x  2 mdickson mdickson        4096 May 23 12:26 .
    drwxr-xr-x  3 mdickson mdickson        4096 May 23 12:01 ..
    -rw-r-----  1 mdickson mdickson         356 May 23 12:05 amp_license.txt
    -rw-r--r--  1 mdickson mdickson  6795952128 May 23 12:15 databackup.tar.gz
    -rw-r-----  1 mdickson mdickson 13583477455 May 23 12:47 nightly_data001.tar.gz
  • 7.  RE: Upgrade path for Airwave 7.6.4 (CentOS 5.5) to Airwave 8.2 (CentOS 6.2)
    Posted May 23, 2016 01:37 PM
    Most likely due to post nightly_maintenance clean up which purges data from the db to match the AMP Setup -> Client Historical Data Retention values.
