Network Management
Contributor II
Using Airwave to backup Controllers
I see that starting in Airwave 8 is possible to use airwave to backup Controllers configuration. But I cannot found how to do this on our envirolment.
On User Guide I did not find any example on how to configure this feature. Someone has an exemple?
We use Airwave as "Monitor" not for configuration change.
Paulo Raponi
Re: Using Airwave to backup Controllers
As long as you have SSH credentials defined, it will automatically backup the controllers. You will see the backups under Audit.
Tim
Tim Cappalli | Aruba Security
Contributor II
I do not find the audit tab...
Can you help me with this?
When you click on a controller, there will be a sub menu at the top that says Audit.
Tim
Contributor II
I did not find the menu ... My user are Admin...
We use Airwave as monitor. Not config change...
In the group settings where your controller lives, be sure "Audit configuration" is enabled.
Tim
