Im starting to get this VSF on how it works however i want to clarifiy some things before I put it into action.
1. Given that I have 2 5406 aruba switch with OOBM MAD configured, how many VSF link should I implement? I'm thinking that it should be only one but I was wondering if I can implement two VSF link, one link will act as primary link and other will be backup.
2. If Im going to implement the OOBM MAD with this configuration,the management ip address for member 1 is 10.30.31.1 and 10.30.31.101 for member 2? correct me if im wrong , but I've read some articles that I should disable the management vlan if im going to implement VSF.
oobm
ip address dhcp-bootp
vsf member 1
ip address 10.30.31.1 255.255.255.0
exit
vsf member 2
ip address 10.30.31.101 255.255.255.0
exit
exit
3. If Im going to implement STP / LACP on the other switches , is there any special procedures when dealing with VSF?
Thanks you for your response.
