Network Management
VisualRF Plan - How to change path for data?
  • 1.  VisualRF Plan - How to change path for data?
    Posted Mar 21, 2016 05:57 AM
    During first installation of the VisuslRF Plan program I choose wrong path for data, and I can't find place to change it. I tried to reinstall program, but now it doesn't ask for it and keeps the wrong path. Where is this path kept?
    Mariusz
  • 2.  RE: VisualRF Plan - How to change path for data?
    Posted Mar 21, 2016 02:11 PM
    When you reinstall, make sure the hidden file in C:\Users\<username>\.vrfplan.pref gets deleted prior to the reinstall.  This is the only path I've found that worked.  I tried editing the file, but VRF Plan doesn't follow the new path.  It'd be a feature enhancement request to make an easier way to change the file path.
  • 3.  RE: VisualRF Plan - How to change path for data?
    Posted Mar 22, 2016 04:13 AM
    Thx, deleting ".vrfplan.pref" file works!
