Network Management
What is the best solution for Network LAN & WLAN ?
one of my client need LAN (70 Devices) & WLAN (500 Devices) network management software. can i propose HP IMC for LAN Management and Airwave for WLAN Management? i want to know can i buy IMC standard and airwave as IMC additional module?
Re: What is the best solution for Network LAN
You would just need AirWave. Please work with your Aruba partner.
Tim Cappalli | Aruba Security
can we do the Network management LAN & WLAN from Airwave? customer required Manage LAN also.
not a monitoring.
Community Manager
Yes you can manage LAN and WLAN hardware with Airwave.
Airheads Community - The best place to Connect. Engage. and Learn.
