Network Management
What rules are required in the logon_role to enable 802.1x authentication
  • 1.  What rules are required in the logon_role to enable 802.1x authentication
    Posted May 31, 2016 07:36 PM
    I am using 802.1x authentication with roles derived from a radius server.I have 3x roles:
    logon_role
    user_role
    quarantine_role
    User and quarantine are user based roles and depending on health check and group access etc are approved access on the network or denied and fall into the quarantine network.
    The login role is for the machine when authenticated it is given the logon_role, i currently have in policy assigned to the role:
    udp 68 deny
    svc dhcp permit
    svc dns permit
    svc icmp permit
    svc natt permit
    any any any deny
    To allow a user login to occur on this machine currently assigned the logon_role what other services or ports need to be allowed in the logion_role/policy
    Thanks heaps
  • 2.  RE: What rules are required in the logon_role to enable 802.1x authentication
    Posted May 31, 2016 07:38 PM
    802.1X happens at L2. Are you talking about a Windows device authenticating to active directory at user login?
  • 3.  RE: What rules are required in the logon_role to enable 802.1x authentication
    Posted May 31, 2016 08:13 PM
    Thats what I thought but when machine authentication occurs it is assigned the logon_role. If a user logs on  the role user_role is assigned when they log off the machine reauthenticates and is given the logon_role again. This process works fine with roles changing as user and machine re authenticate.
    The problem I am having is when the machine is restarted it is not receiving a role at startup, at this point i can disconnect the ethernet cable and reconnect and a role is then defined. Or if I change the last rule any any any deny in the policy to allow for some reason this works to. This is why i suspect a rule needs to be added to the policy as I am then getting hits on the rule in the firewall.
    I have changed the machine group policy to wait for network initialisation before login but has not made any difference.
  • 4.  RE: What rules are required in the logon_role to enable 802.1x authentication
    Posted May 31, 2016 08:43 PM
    Machine authentication should have an "allow all" role.  That is equivalent to a machine being plugged in via ethernet at the Windows Login prompt.  The user has no rights to do anything interactively, but the machine itself should have to right to do everything, like Windows updates, administrators to open shares, RDP, etc.
  • 5.  RE: What rules are required in the logon_role to enable 802.1x authentication
    Posted Jun 01, 2016 04:05 PM
    Thanks Colin
    Have added an allow all rule but the same issue is still there.
    When the Win7 client boots it is not assigned a role - Radius indicates that the PC did not match a connection policy.
    However if i unplug the ethernet connection and plug in again forcing the network adapter to reset and the PC to re authenticate then it is assigned the logon_role. This doesn't occur 100% of the time but it would be at least 80% over all clients. PC is fully updated and meets all the health requirements they just stumble slightly at startup. Logging in with a user account at this point will assign the user_role and then log off will allow the PC to reauthenticate and it will then pickup the logon_role. Its just not occuring at startup.
  • 6.  RE: What rules are required in the logon_role to enable 802.1x authentication
    Posted Jun 01, 2016 04:37 PM
    Wait...
    Is this a wired or wireless device?  What is the wired device plugging into?
  • 7.  RE: What rules are required in the logon_role to enable 802.1x authentication
    Posted Jun 01, 2016 05:25 PM
    These are wired devices connected to the wired port on a RAP-155
  • 8.  RE: What rules are required in the logon_role to enable 802.1x authentication
    Posted Jun 01, 2016 08:56 PM
    The radius server probably rejected it, because the computer account is a member of the "Domain Computers" AD group.  That group needs to be allowed to successfully authenticate machine-authenticated devices.
  • 9.  RE: What rules are required in the logon_role to enable 802.1x authentication
    Posted May 31, 2016 07:42 PM
    You don't need any rules to allow 802.1X authentication. The Rules mostly operates on L3 and 802.1x runs on lower layer.
